Brakes
394,000 MILES • 2WD • AUTOMATIC
JORDAN WHITSON
Ive changed the brake hose, the caliper and the master cylinder and its still leaking . What do i do?
Sep 4, 2016 at 12:07 PM
CARADIODOC
  • 34,413 POSTS
Where is it leaking? You replaced parts in three different places.
Sep 4, 2016 at 12:13 PM
JORDAN WHITSON
I worded it wrong im sorry, its leakinf from where the hose connects to the caliper
Sep 4, 2016 at 12:15 PM
CJ MEDEVAC
  • 11,000 POSTS
Different and better lookin' feller! LOL!
I have a link to one of your brake hoses below
http://shop.advanceautoparts.com/p/carquest-wearever-brake-hydraulic-hose-bha380556/18650861-P?searchTerm=brake+hoses+%26+lines
See dem copper rings in the center of the curled hose?
See the "block" on the end of the hose (left side of pic)
A copper ring (this is the seal) goes on either side of the block, the bolt runs thru one ring, the block, the other ring and then threads into the caliper.
I don't have your torque specs for the bolt, I do know that it is at least 25 ft-lbs. Should this not do it, send me your VIN and I'll try to look it up. At the present you did not give all of the necessary info to look it up (one being your engine size)
Insure you don't have new rings stacked on top of old ones that may be stuck on the caliper!
This do you any good?
The Medic
Sep 4, 2016 at 12:49 PM
