Brakes leaking from driver side rear
2005 FORD F-250
150,000 MILES • 6.2L • V8 • TURBO • 2WD • AUTOMATIC
PHILLIPSTEINBERG
Pedal goes to floor. Notice fluid coming from driver side rear brake.
Sep 9, 2019 at 6:25 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Losing brake fluid from what you've mentioned is an obvious leak in the system. You will need to remove the tire to see if a brake line or the brake caliper is loose/broken/defective. I would suggest having it repaired as soon as possible. Your truck should not be driven until repaired for fear of losing brakes entirely. Here is a tutorial to view to get you started on what to look for:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Once you figure where the leak/defect is the whole brake system will need to be bled.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Hope this helps and thanks for using 2CarPros.
Danny-
Sep 9, 2019 at 8:21 AM
