Brakes squealing when braking
92,000 MILES • 1.1L • 4 CYL • 2WD • AUTOMATIC
STEVIE12
  • 55 POSTS
My brakes are squealing when replacing brakes. should I get new rotors also? Thanks
Jul 25, 2021 at 9:22 PM
Good morning,
I would always replace rotors with every brake job.
Make sure you use ceramic brake pads to eliminate the squealing.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Metallic pads contain bits of metal. When they get hot, the metal comes to the surface and contacts the rotor giving you the noise.
Use premium rotors. The cheap ones will make noise and warp from heat.
Jul 25, 2021 at 10:14 PM
STEVIE12
  • 55 POSTS
Thank you. someone told me I should replace calipers. what's your opinion?
Jul 25, 2021 at 10:18 PM
Only if you have issues with the brakes pulling one way or the other.
Jul 25, 2021 at 10:39 PM
STEVIE12
  • 55 POSTS
Jul 25, 2021 at 10:45 PM
You are welcome.
Always glad to help.
Jul 25, 2021 at 10:47 PM
STEVIE12
  • 55 POSTS
Roy, one more question. I do not have pulling but if I need calipers can I still put brakes and rotors on without new calipers until next week due to not having the money?
Jul 25, 2021 at 11:15 PM
Sure. I would make sure you still have the issue after you replace the pads and rotors.
https://www.2carpros.com/articles/brake-caliper-replacement
Jul 25, 2021 at 11:29 PM
STEVIE12
  • 55 POSTS
Thank you Sir.
Jul 26, 2021 at 3:17 AM
You are welcome.
Jul 26, 2021 at 3:21 AM
