Brakes
240,011 MILES • V8 • AUTOMATIC
CONWAYNE
Brakes go to the floor but brake fluid is full, I guess they kind of go a little over halfway before they catch, then they go down even further! A small brake fluid leak would not cause that, right?
Apr 21, 2016 at 2:13 AM
HMAC300
  • 48,601 POSTS
it can be a leak, the master may be shot, air in system like abs unit especially if a brake job was recently done.if you are going to bleed brakes use a power bleeder.
Apr 21, 2016 at 2:27 AM
CONWAYNE
Thank you, one more question could it be the booster?
Apr 21, 2016 at 2:49 AM
HMAC300
  • 48,601 POSTS
It sounds more like a hydraulic issue or brakes are worn out, can you check them and get back to us?
Apr 21, 2016 at 5:19 AM
