Brake pedal goes to floor
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
STAIN22$
Brake pedal goes to the floor not right away.
Oct 5, 2019 at 8:44 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome to 2CarPros.
Are you saying when you step on the brakes the pedal slowly sinks until it hits the floor?
Do you see and fluid leaking anywhere or puddles on the ground?
If there are no leaks then your master cylinder has probably failed and needs to be replaced. Here is a guide to get you going:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Rich
Oct 5, 2019 at 4:07 PM
STAIN22$
Thanks.
Oct 6, 2019 at 4:42 AM
94 TRANSAM
  • 680 POSTS
My pleasure, Let me know if you need more help.
Rich
Oct 6, 2019 at 8:58 AM
