I feel as in my brake pedal goes down as it pumps down by itself
127,000 MILES • AUTOMATIC
NITZA24
I have a problem with my vehicle and I really do not know what is the problem. I do not know if I need brake lines. I got my brakes and rotors check and I was told that they are in good condition. But as I drive I have to push down to get my vehicle to stop, when I do finally stop I feel as in my brake pedal goes down as it pumps down by itself while I am at a light or stop sign. I checked my brake fluid and it is good.
Dec 18, 2016 at 3:53 AM
Here are the master cylinder installation instruction you have requested. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/WDxvEQrMkBg
and
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Plus here is a guide that will help with this issue:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Below you will find instructions from the manual that will get you anything else you need.
Lastly you will need to bleed the brakes so here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Mar 12, 2021 at 9:28 AM
