When braking hard the brake pedal went to the floor?
2006 DODGE DAKOTA
230,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
JLANDRY
The brakes went out. I would mash the brake and it went to the floor. so, I changed the master cylinder and booster and then I could barely push on the brake, it was too hard. I changed the brake shoes and bled the brakes in the correct order. I drove it a short distance and they seemed fixed. The next time I drove it after about 2 miles I had to stop and loosen them because they were sticking and started smoking. Long story short, I thought they were fixed until I got stuck in a mudhole. When I got unstuck and started driving the brakes were grinding and growling and started sticking again. What could have happened?
Jan 12, 2024 at 2:58 PM
  • 110,244 POSTS
Are all brakes doing this or is it a specific one? As far as replacing the rear brakes and then having a softer pedal, I don't know how that is possible.
Reinspect under the dash to make sure nothing is preventing the brake pedal from fully releasing. Also, if it is limited to one brake, let me know that as well.
I will watch for your reply.
Jan 13, 2024 at 8:22 AM
