no brakes at all to be able to drive?
250,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
B.EDWARDS1990
The brakes went out on my car so I was replacing them and I noticed the brake line to the driver back wheel had been cut so I bought the stuff and repaired the line with flaring tool, line, etc. I put brake pads on all wheels and tried to bleed them and no e would bleed because bleeder valves were stuck. I bought 2 new calipers and put on front(yes they are on right, valve at top)and they bled fine. But there was no brakes at all to be able to drive it. The master cylinder had no cap so I bought one, took master cylinder off and emptied out fluid, cleaned, put new fluid in it. Still no brakes. It has also developed a vac leak under the hood I can't find and after it runs a few mins u start to hear the hissing sound and the car acts as if it's gonna die then comes back up then dies down then back up over and over at idle. The back passenger side caliper would bleed if u turned the banjo nut, I got the valve unstuck, now no fluid to it and no fluid to back drivers side where I replaced the broken line. The brakes worked before but they needed changed because it would hardly stop and had started screeching. By changing brake pads this is what my results have been. Multiple people have looked at it and no one knows what to do. Idk if it's the master cylinder, or what. The brake pedal is very easy to push there is no pressure at all and goes straight to the floor. Changing brake pads has lead to my car being set up for close to a year now because it can't be driven at all because it has literally no brake at all. And I can't figure out why the 2 new calipers on the front aren't giving it at least brakes In the front. What can I do?
Feb 25, 2026 at 2:43 AM
  • 55,594 POSTS
It does sounds like the brake booster and master are bad. I know you removed it and flushed it out but this video will show you if the master is working, also before you remove the master remove the check valve of the booster to see if you hear air/vacuum escaping, if not the booster is bad. Please go over this video which can help you see if fluid is being moved inside the master.
https://www.youtube.com/watch?v=WDxvEQrMkBg
Please upload a short video in your response of the problem, so I can see what's going on. Ken
Feb 25, 2026 at 11:51 PM
