bleeding brakes
109,000 MILES • 1.3L • 6 CYL • 2WD • MANUAL
HEARTS
Changed the pads and calipers and rotors on TDI. Driver side will not bleed.
Jul 28, 2018 at 7:44 PM
  • 55,732 POSTS
When you mean not bleed do you mean not fluid comes out or that air keeps coming out of the bleeder? If the fluid is not coming out I would crack the line loose at the caliper and then push on the pedal to see of the caliper is getting pressure and it is a bleeder issue. If no pressure is observed I would expect the brake flex hose from the frame to the caliper. Here is a video and guide below to help you bleed the brake system correctly.
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://youtu.be/WDxvEQrMkBg
Jul 31, 2018 at 5:09 AM
