The rear of my car is making a grinding noise changed the brakes, but it is still there.
Jun 28, 2017 at 4:37 AM
HMAC300
✓Experienced Mechanic
check the wheel bearings as that may be the problem, drive in a right circle if noise is more predominant it is the opposite side. if a left circle vice versa. Also, check rear end fluid.
