Brakes
100,000 MILES • 2.5L • 4 CYL
HOPE ROWE
Driver side front brake will not bleed.
Mar 26, 2017 at 5:23 AM
HMAC300
  • 48,601 POSTS
it is more than likely an abs problem or a brake hose try a power bleeder but if It still will not bleed then a mechanic will need to hook his scanner up and open valves with scanner then bleed it. if it still bleeds that way then it may be a bad ABS unit which can be rebuilt.
Mar 26, 2017 at 5:44 AM
CJ MEDEVAC
  • 11,000 POSTS
Without touching the pedal
Have a Bobby Pin/ tiny drill bit/ anything similar ready, along with some spray brake cleaner (*Safety Glasses*)
Quickly/ Fully unscrew the bleeder and crunch out any mud/ etc. from the hole in the end and the one going in sideways at the other end. Spray it clean with the brake cleaner.
Quickly reinstall the bleeder.
Bleed.
Was this the issue?
The Medic
Mar 26, 2017 at 5:51 AM
HOPE ROWE
Brake valve is open car has non abs
Mar 26, 2017 at 7:12 AM
HMAC300
  • 48,601 POSTS
then check for it being blocked you can take the bleeder screw out as long as you don't touch brake pedal and see if it is blocked at bottom. then if all that is clear and still doesn't bleed i'd say it's the hose is bad not allowing fluid to pass.
Mar 26, 2017 at 8:46 AM
HOPE ROWE
Ok I'll try that thanks I'll let u know
Mar 26, 2017 at 9:14 AM
HOPE ROWE
Ok 96 mazda protege front drivers side brake problem is proportioning valve has to be replaced it's a dealers part in case anyone else has this problem thanks everyone for your help
Mar 27, 2017 at 8:19 AM
