Brakes
263,000 MILES • 6 CYL • FWD • AUTOMATIC
PSLATER0619
I am having an issue with losing brake pressure when trying to stop, brake pedal goes to floor. I have brake pressure before starting van and in park. Does not lose pressure until in gear.
May 23, 2017 at 6:06 AM
HMAC300
  • 48,601 POSTS
first check to see if fluid is full in master, then if recent repair work was done on brakes have a mechanic use his scanner to open valves on ABS unit and bleed the system. Most likely it has air in it. I am assuming that there are no leaks in lines and brakes are in good working order.
Mar 15, 2021 at 5:41 AM
PSLATER0619
No work has been done as of yet on the van. I noticed the problem last week, would lose pressure and pedal would go to floor. Pumped brakes a few times and pressure came back. That happen about three different times. When I went to leave my driveway yesterday had pressure in brakes until I put van in gear and went to stop, then brakes went to floor with no resistances. I am strongly leaning towards master cylinder.
HMAC300
  • 48,601 POSTS
yes, it probably is the master has gone bad especially since you say it pumped up then went to floor.
PSLATER0619
Will keep you posted, son went to get new master cylinder and is going to be installing it soon.
PSLATER0619
It was definitely master cylinder, awesome pressure now.
RENEE L
  • 1,260 POSTS
Hi PSLATER0619,
Glad to hear you were able to fix your brake problem. thank you for visiting 2CarPros please tell your friends.
Kindest regards,
Renee
Admin
