Why does the left front brake caliper keep hanging up?
60,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
CARL BIENZ
I replaced calipers rotors and pads and brake hoses three times in the last 2 weeks the left front caliper continues to hang up. What seems to be the problem?
Sep 1, 2022 at 3:09 AM
SQM
  • 6,383 POSTS
A sticking caliper can happen due to the brake fluid not retrieving when the brake pedal is released. It could be due to a bad caliper or hose. Since you have already replaced them. The issue could be further up, like on the brake line or even on the brake control module.
Faulty module can cause the brake to stick or even lock up.
Try to bleed the brakes with the brake hose off and see if you are getting strong flow.
Also look for any issues on the brake line.
Are you getting any error lights on the dash? Like ABS or traction control light?
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Let me know of any questions.
Sep 1, 2022 at 1:25 PM
