Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
BMW
320D
General
Noises
Squeal
After replacing the brake they squeal at low speeds
2010 BMW 320D
72,000 MILES
B WEST
MEMBER
1 POST
my car has new brake discs and pads but now the brakes squeal as they get warmer but only at low speeds are when I brake slightly.
Apr 2, 2021 at 7:04 PM
Experienced Mechanic
Good morning,
When I do one of these, especially BMW, I use only factory parts. Pads, rotors and sensors are the brake job.
Did you use BMW parts?
The issue most likely is the material of the pads. The metal comes to the surface when they get hot resulting in the noise.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Images (Click to enlarge)
Apr 2, 2021 at 9:51 PM
Add image or video
Ask a new question
Engine won't start
Engine — Oil Leak
