What is a fair price to get front brake rotors and pads installed?
163,000 MILES • 6 CYL • 4WD • AUTOMATIC
SILENTHILLDALE
  • 18 POSTS
Brakes replacement cost. What is a fair price to get front brake rotors and pads installed?
Apr 20, 2023 at 2:53 PM
  • 55,688 POSTS
Brake parts prices are all over the map because of the variance in part quality. Here are factory prices which you should be able to get the parts for less, I have also included instructions on how to change out the brakes in case you want to do the job yourself in the images below.
Rotor 45251STXA00 - $138.70 each.
Front Pads 45022STXA00 $80.22 a set.
Labor 1.4 hrs @ shop labor rate
This video shows the job being done as well on a similar car:
https://youtu.be/-HDVldGwHTU
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Apr 21, 2023 at 9:31 AM
