Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
3
Brakes
Pads
Rear
Brakes
2012 MAZDA 3
85,000 MILES
FALCONSBB
MEMBER
1 POST
dashboard brake warning light on I need new brakes.
Dec 9, 2019 at 3:23 AM
Experienced Mechanic
Here is a guide that will help with replacing the rear brakes: This video shows the job being done on a similar car but the process is the same.
https://youtu.be/G5M_xKIxUb4
and
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Plus below you will find the process from the manual that will give the detail needed to get these replaced. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to enlarge)
Mar 11, 2021 at 9:58 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
