Brakes
210,654 MILES
EV COLSON
I started the car put it in reverse and i can not go anywhere my brakes have locked up the light is on and it says low break fluid why are my breaks locked up and how can i fix this problem.
Mar 21, 2017 at 3:20 PM
HMAC300
  • 48,601 POSTS
it may be due to low brake fluid, something may have gotten into ABS unit. I have a mechanic try to bleed system with his scanner. but from your description probably brake fluid was never changed and now dirt is in ABS unit locking your brakes.
Mar 22, 2017 at 12:46 AM
