brakes not working propperly?
390,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
HAYES5
pedal went almost to the floor but stopped the truck. hissing sound in the cab so we changed the booster. pedal is now hard to push with little braking power and still a slight hiss. checked out the check valve seems to be okay.
Apr 19, 2023 at 12:26 AM
  • 55,837 POSTS
It sounds like the brake master cylinder went out here is how to replace the unit which must be bled before it is installed. Also, check the front and rear brake pads/shoes. Here is a guide and a video to help and the instructions on how to replace the master on your truck in the diagrams below:
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
This guide may help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Apr 20, 2023 at 1:48 AM
HAYES5
i bled the master cylinder and then bled the brakes. the pedal felt better but the brakes did not work.
Apr 28, 2023 at 1:12 PM
  • 55,837 POSTS
Can you explain the brake not working, do you have good pedal? does the brake have pedal but not stop the car? Can you please shoot a quick video with your phone so I can see what's going on? that way I can tell for sure what's going on.. You can upload it here with your response.
Apr 29, 2023 at 4:29 AM
HAYES5
yes, the brake has pedal but does not stop the car.
Apr 30, 2023 at 8:01 AM
  • 55,837 POSTS
Okay, start the car and then shut it off, then remove the vacuum check valve from the booster and you should hear vacuum escaping, if not the booster is defective and needs to be replaced.
May 1, 2023 at 3:14 AM
HAYES5
After i bled the brakes, the braking system is now fully functional. Thank you Ken L for your knowledge and helpful hints.
May 9, 2023 at 1:51 AM
  • 55,837 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
May 10, 2023 at 3:54 AM
