Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Kia
Rondo
Brakes
Symptoms
Pedal Goes to the Floor
Brakes
2007 KIA RONDO
130,000 MILES • 6 CYL • AUTOMATIC
SANDRAD62
MEMBER
1 POST
After replacing master cylinder and pedal still goes to floor how to tell before spending more money that it is ABS hydraulic unit?
Oct 16, 2018 at 6:15 AM
MOTOR MASTER
Experienced Mechanic
Hello, My name is Dave.
It sounds like the problem is either air in the system or the master cylinder was not thoroughly bench bled. I have attached links to two guides that should assist you in finding the issue.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
I believe one or both of these will be very helpful in finding the issue. If you need further assistance please let us know and we will be glad to help in any way we can and thank you for using 2CarPros
Oct 18, 2018 at 2:33 AM
Add image or video
Ask a new question
Check engine light
Brakes — Pedal Spongy
