brake light turned on
110,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
JAMES REICHLE
brake light came on reservoir was half empty. filled to top, brakes still sluggish.
Jan 13, 2018 at 6:30 AM
CARADIODOC
  • 34,415 POSTS
The reservoir should not be filled. If the fluid level is low, there is either a leak that must be addressed or the front brake pads are worn to the end of their life, and a brake system inspection is in order. If the front pads must be replaced, the pistons that self-adjusted out of the calipers will have to be pressed back in. That is going to send brake fluid up to the reservoir where it will overflow and make a mess.
What is sluggish, the vehicle's acceleration? The brake pedal is low and mushy?
Jan 13, 2018 at 6:51 AM
