Front brakes torque specs
200,000 MILES • V8 • AUTOMATIC
SWEETIE1965
  • 188 POSTS
Would you know the torque specs for an the front brakes for this vehicle? I specifically need the guide pin torque specs and the banjo bolt torque specs. Thanks in advance.
Dec 24, 2019 at 1:56 AM
STEVE W.
  • 15,418 POSTS
The slide pins are 22 ft lbs, The banjo bolt show 145 inch pounds.
Dec 24, 2019 at 2:16 PM
SWEETIE1965
  • 188 POSTS
Would you also know the minimum thickness for front rotors? Some are stamped on the rotors but some are not. Thanks again in advance for your help.
Dec 25, 2019 at 2:16 AM
STEVE W.
  • 15,418 POSTS
Rotor specs -
13.3" dia.
Max run out - .004
Max thickness variation - .0005
Min. thickness - .89" or 57/64"
Dec 25, 2019 at 4:35 AM
SWEETIE1965
  • 188 POSTS
Thanks a bunch.
Dec 25, 2019 at 5:02 AM
SWEETIE1965
  • 188 POSTS
Would you have the torque specs for lower control arm, brake mounting bracket and banjo bolt for the vehicle listed above? I'm not sure if the control arm bushing bolt has a torque spec or not. I just asked. Thanks in advance.
Jan 31, 2020 at 10:06 PM
STEVE W.
  • 15,418 POSTS
For the A arm -
Pivot bolts through the bushings (1) Front bolt 80 ft lbs Rear bolt 140 ft lbs
Shock mount bolt - 80 ft lbs
Ball joint stud - 135 ft lbs
Brake mounting bracket - Doesn't have them, the caliper and pads slide on ears that are cast into the steering knuckle. It is held in place by the caliper pins.
Caliper pins are torqued to 22 ft lbs.
Banjo bolts are all 145 In Lbs using new seal washers.
If you are installing new calipers but still have the old master cylinder be careful when bleeding them that you don't push the pedal down all the way, they tend to build up rust and crud in the bore and pushing the pedal down drags the pistons through that. Then you end up with a sinking pedal because the fluid leaks past the seals.
Jan 31, 2020 at 10:56 PM
SWEETIE1965
  • 188 POSTS
I just replaced both u joints on a 2005 Chevy avalanche. Now it doesn't catch up the speed that it used to. I don't see anything wrong with the installation. What can cause this? It started only after changing the u joints(front and rear). It has no hanger bearing (center u joint).
May 8, 2020 at 3:23 AM
STEVE W.
  • 15,418 POSTS
Could you ask that as a new question please. https://www.2carpros.com/questions/new
That will get more eyes on the question.
May 8, 2020 at 9:23 AM
RENEE L
  • 1,260 POSTS
My name is Renee and I am the site's editor. Regarding starting a new question Steve mentioned in his post above. The reason being; in order for the site to properly index questions they need to about one issue/vehicle otherwise people will not be able to find the answer to that question under a different subject. The site is here to assist those that need direct help but also provide a resource for others that have the same issue.
Make sure you are logged into the site before clicking on the link Steve put in his post.
Thank you for using 2CarPros and have a great rest of your day!
Renee
May 9, 2020 at 3:50 AM
