Brake pedal goes to the floor?
2007 FORD FALCON
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
MEG73
Brake pedal goes to floor, then brakes.
Feb 20, 2024 at 6:55 PM
  • 110,190 POSTS
First, make sure the brake fluid is full. If it is, then suspect the brake master cylinder has failed. If it isn't full, check for leaks.
Take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Feb 20, 2024 at 8:43 PM
