Brake bleeding issue
130,000 MILES
OLSKWL
No fluid to back brakes when bleeding or very little, Brake pedal very spongy.
Mar 10, 2020 at 11:38 PM
94 TRANSAM
  • 680 POSTS
It sounds like either you have air in the master cylinder or the rear plunger has failed. It could also be a plugged proportioning valve.
If you have someone step on the brake and crack the rear line lose on the master what kind of flow do you have there? Note do not let the brake pedal up until you re-tighten the line or you will let air into the master.
Rich
Mar 11, 2020 at 4:37 AM
  • 55,658 POSTS
Here is a brake bleeding guide to help also a low brake pedal troubleshooting guide as well:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 11, 2020 at 7:45 AM
OLSKWL
I put on a new master cylinder that seem to do the trick so far. Thank you for all the input.
Mar 11, 2020 at 1:23 PM
94 TRANSAM
  • 680 POSTS
Sure, let us know if you need anything else.
Rich
Mar 11, 2020 at 1:48 PM
