Randomly the brake pedal sticks to the floor
176 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
CRAFTSMAN62
  • 18 POSTS
I have,already posted my brake problem. Thank you.
Feb 29, 2020 at 10:11 AM
  • 110,248 POSTS
I checked back through all unanswered questions and nothing is there. I'm not sure why it didn't come through to us. What is happening and how can I help?
Aug 27, 2020 at 11:31 AM
CRAFTSMAN62
  • 18 POSTS
hi, let me try again on my truck listed above my brake pedal sticks to the floor. sometimes it releases on its own or I can turn the engine off it will release it. does not stick all the time.
CRAFTSMAN62
  • 18 POSTS
my front wheels don't lock up just my left rear wheel.
  • 110,248 POSTS
Okay, is the brake fluid staying full? The idea that only one brake is working (rear) tells me there is either a fluid issue or the master cylinder has failed. Also, the idea that the brake pedal stays to the floor until the engine is turned off is really odd but is most likely related to a faulty vacuumed controlled brake booster.
First, try something. Do not drive the vehicle like this, but I want you to disconnect the vacuum supply to the brake booster behind the master cylinder. The brakes should become hard to press. Tell me if the pedal still sticks. Also, the idea that the pedal goes to the floor is a strong indicator that if the brake fluid is not low, the master cylinder has failed.
Take a look through this link:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Check to confirm there are no leaks under the vehicle and that the fluid is full. Also, disconnect the vacuum hose to the booster and see if the pedal still is sticking.
Let me know the results.
CRAFTSMAN62
  • 18 POSTS
yes, i will trouble shoot and let you know. and go from there. thanks for the info.
  • 110,248 POSTS
Not a problem. I will watch for your reply.
CRAFTSMAN62
  • 18 POSTS
okay, it will be tomorrow. Dennis
  • 110,248 POSTS
Not a problem. The biggest concern is if the brake fluid reservoir is low or empty. Also, let me know if the brake light is on and if the vehicle has ABS.
CRAFTSMAN62
  • 18 POSTS
i am sorry, I haven't got back to my brakes yet. I got a new problem in dealing with. I was changing out my thermostat and broke the bolt off in my intake. so I am dealing with that now soon as I get that resolved I will get back on my brakes. somebody put lock tight on the treads an that's why it broke off. Dennis
  • 110,248 POSTS
Dennis,
Not a problem. Take care when removing the broken bolt. Make sure you center the drill and use a quality easy out. You don't want to break that off in the bolt. They are nearly impossible to drill.
When you get to it, let me know.
CRAFTSMAN62
  • 18 POSTS
I tried easy out, didn't work. I figure the lock tight kept it from coming out. how i got the other bolt out was pure luck. I drill it out am going to hardware store tomorrow and get a self tapping bolt that will fix it.
CRAFTSMAN62
  • 18 POSTS
It's aluminum so it shouldn't b a problem cutting new threads. have a good night. Dennis
  • 110,248 POSTS
No, you should be fine. Take care and let me know how things turn out.
CRAFTSMAN62
  • 18 POSTS
Got a problem changed out my thermostat discover I have small hole right next to where my thermostat sits. I had a small leak now I know where my water was going. what is best to seal the hole? I had to add a little water every now and then. what do you recommend?
  • 110,248 POSTS
Can you upload a pic of the hole so I can see what you are dealing with? If it is aluminum you are dealing with, the right way is to mig weld. They make products for metal repairs, I don't know how well they can take the pressure.
CRAFTSMAN62
  • 18 POSTS
You will have to blow it up to see the hole it's to the right of the bolt hole the hole is not all the way though it's just enough to cause a leak.
CRAFTSMAN62
  • 18 POSTS
There is a bunch of sealants epoxy's out there like JB water weld an others I been told that gorilla glue got some stuff out that might work I just don't know which one I sure go with. I know in time I will have to replace the intake but maybe I can prolong it until it starts getting warmer and I have more funds.
CRAFTSMAN62
  • 18 POSTS
I decided to just go ahead an get me a new manifold an b done.
  • 110,248 POSTS
Actually, that is the best thing to do. Let me know when we can get back the brake issue.
I don't know if you need them, but here are the directions for both the upper and lower. They include torque specs and tightening sequence. The attached pics correlate with the directions. I will start with the upper.
Normally, you can remove the lower without taking the upper off. However, since the lower one needs replaced, I included info related to the upper as well.
_______________________________________
1996 Chevy Truck S10/T10 P/U 2WD V6-4.3L VIN W
Intake Manifold Replacement (Upper)
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures Intake Manifold Replacement (Upper)
INTAKE MANIFOLD REPLACEMENT (UPPER)
Upper Intake Manifold And Components
pic 1
Upper Intake Manifold Installation
pic 2
REMOVE OR DISCONNECT
1. Negative battery cable.
2. Drain the engine coolant.
3. Air cleaner inlet duct.
4. Wiring harness connectors and brackets.
5. Throttle linkage and bracket.
6. Fuel lines and bracket at the rear of the lower intake manifold.
7. Brake booster vacuum hose.
8. Ignition coil.
9. PCV pipe and vacuum hoses.
10. Purge solenoid and bracket.
11. Upper intake manifold bolts and manifold. Mark the location of the bolts for proper reassembly.
INSTALL OR CONNECT
1. New upper manifold gasket with sealing lines facing up.
2. Upper intake manifold. Do not pinch the injector wires between the upper and lower intake manifolds.
3. Upper intake manifold bolts and studs noting the marks made during disassembly. Tighten the bolts in two steps:
a. Tighten to 5 Nm (44 in lbs).
b. Tighten to 10 Nm (88 in lbs).
4. Purge solenoid and bracket.
5. PCV pipe and vacuum hoses.
6. Ignition coil.
8. Fuel lines and bracket at the rear of the lower intake manifold.
9. Throttle linkage and bracket.
10. Wiring harness connectors and brackets.
11. Air cleaner inlet duct.
12. Negative battery cable.
13. Fill and recheck engine coolant level.
14. Inspect for leaks:
a. Turn the ignition switch to the "ON" position for 2 seconds.
b. Turn the ignition switch to the "OFF" for 10 seconds.
c. Turn the ignition switch to the "ON" position.
d. Check for fuel leaks.
Intake Manifold Replacement (Lower)
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures Intake Manifold Replacement (Lower)
INTAKE MANIFOLD REPLACEMENT (LOWER)
pic 3
Applying Sealant To The Rear Of The Block
pic 4
Applying Sealant To The Front Of The Block
pic 5
Tightening Sequence
pic 6
2. Drain the cooling system.
3. Air cleaner intake duct.
7. Vacuum hoses to upper and lower intake manifolds.
8. Distributor. Mark the housing and rotor positions for proper reassembly.
9. Upper radiator hose at the thermostat housing.
10. Heater hoses at the lower intake manifold.
11. Wiring harness and brackets.
12. Transmission oil level indicator and tube (automatic transmissions only).
13. Air conditioning compressor and bracket.
14. EGR tube, clamp, and bolt.
15. Alternator bracket bolt next to the thermostat housing.
16. Lower intake manifold bolts and manifold.
17. Clean gasket surfaces, carbon buildup and deposits from EGR and exhaust passages. Also, scale and deposits from coolant passages.
18. Inspect manifold for cracks, broken flanges and gasket surface damage.
INSTALL OR CONNECT
1. Gaskets onto the cylinder head with the port blocking plates facing the rear of the engine and the "This Side Up" stamping facing up.
2. Apply a 5 mm (1/4 inch) thick bead of Wacker T-330 RTV, GM P/N 12346192 to the front and rear sealing areas of the engine block and intake manifold. Extend the RTV bead 13 mm (0.499 inch) up the cylinder head in order to seal and retain the gaskets.
3. Lower intake manifold to the engine and apply sealer to the lower intake manifold bolts.
4. Install the lower intake manifold bolts. Tighten bolts in sequence and in three steps:
a. First sequence to 3 Nm (27 in lbs).
b. Second sequence to 12 Nm (106 in lbs).
c. Final sequence to 15 Nm (11 ft lbs).
6. EGR tube, clamp, and bolt.
7. Air conditioning compressor and bracket.
8. Transmission oil level indicator and tube (automatic transmissions only).
9. Wiring harness and brackets.
11. Upper radiator hose at the thermostat housing.
12. Distributor. Noting the housing and rotor positions as marked during disassembly.
13. Vacuum hoses to upper and lower intake manifolds.
14. Fuel lines and bracket at the rear of the lower intake manifold.
15. Throttle linkage and bracket.
16. Wiring harness connectors and brackets.
17. Air cleaner intake duct.
18. Fill and recheck the coolant level.
19. Negative battery cable.
20. Inspect for leaks:
Hope this helps.
CRAFTSMAN62
  • 18 POSTS
Thanks for the info. I got stressed out over this, so I took a step back for a bit and thought about it. First the part store order the wrong part they order the upper in stead if the lower. so I an thinking about what to do next changing out everything is a lot of work. I've done this kind of work before but it has been a while and engines have changed a lot since I have done this. last time I done this was on a 1988 Dakota.
  • 110,248 POSTS
You will be okay. The Dakota didn't have an upper and lower, but it is still basically the same. Let me know what you decide or if you have other questions.
CRAFTSMAN62
  • 18 POSTS
I got Permatex steel and metal weld and going to put a threaded stud in the bolt hole an fill it with Permatex steel an metal weld and let it sit and dry good overnight and put some in that little hole. maybe this will buy me some time. I will see how it goes an go from there.
  • 110,248 POSTS
Sounds like a plan. Keep me in the loop. Hopefully that will buy you some time. However, I feel really confident you will be able to replace the manifold when you are ready.
CRAFTSMAN62
  • 18 POSTS
The permatex held long enough for a text short drive an that was it. It started leaking. So I found a self tapping bolt so I am good now.
CRAFTSMAN62
  • 18 POSTS
I will get back on my brakes as soon as I can. I am carrying a jug of water an antifreeze mix just in case.
  • 110,248 POSTS
Not a problem. I'll be here.
CRAFTSMAN62
  • 18 POSTS
Thanks man for all your help I appreciate it.
