brakes go way down if you press the peddle more than once
76,000 MILES • 4.9L • V8 • FWD • AUTOMATIC
KENKBSLI69
When you first hit brakes they are fine. When you let off and press back down they go way down.
Sep 30, 2016 at 10:02 AM
CARADIODOC
  • 34,414 POSTS
That is a common symptom of a failing master cylinder. Most of the time you can make it occur by lessening the pressure on the brake pedal but not removing your foot completely. Easing up on foot pressure, then applying it harder again allows the internal leakage to take place around the rubber lip seals, then the pedal will sink to the floor again. The same may happen if you hold steady light-to-moderate pressure on the pedal. An additional clue is you will not be losing brake fluid from the reservoir.
Sep 30, 2016 at 1:34 PM
