brakes
135,000 MILES
SUNSHINE001
my brakes apply themselves when the day becomes warm and they release when the temp drops again. can't move if temps are over 60' f. replaced the master and bled but no different. summer's coming, help!
May 19, 2013 at 4:36 AM
CARADIODOC
  • 34,414 POSTS
I assume you mean they don't release, not that the brake pedal moves on its own. If you can get them to drag or lock up, stop on a slight incline, shift to neutral, place a block about 6" downhill from a tire, then loosen the steel lines at the master cylinder to see if they release. If not, open the caliper bleeder screws. You're looking for where the brake fluid is being trapped.
May 19, 2013 at 4:51 AM
