brakes
1998 HYUNDAI ELANTRA
80,000 MILES
BASSGEEZER
a red fluid (probably transmission) was added to the master cylinder. the front brakes are hanging up but not locked. it probably happened several months ago. can I get away with only replacing the master cylinder? can I bypass the abs system and replace everything else?
Apr 20, 2013 at 7:53 AM
every piece of rubber must be replaced. master cylinder, brake hoses, calipers, wheel cylinders, abs unit.
Apr 20, 2013 at 7:57 AM
