After replacing front brakes and bleeding system pedal goes to the floor
1988 GMC S15
179,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DOAUSI
  • 16 POSTS
Had to replace part of front brake line. New pads and calipers on front. Bled brakes until solid fluid came out. Pedal was firm.
Started engine and pedal went to floor. What is the problem here?
What do I need to do or redo?
Thanks,
Dec 5, 2018 at 2:51 AM
Good afternoon,
Did you bleed the rears as well?
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Do you have ABS?
You may need to get a pressure bleeder to force the air out of the system. If all the air is removed then you lost the master cylinder.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Dec 5, 2018 at 3:48 AM
DOAUSI
  • 16 POSTS
Thanks Roy!, No ABS in this old truck. Have not bled the rear brakes, I will jump on that right away as well as redoing the front.
Dec 5, 2018 at 4:09 AM
Okay, sounds like a plan.
Keep us updated.
Dec 5, 2018 at 4:17 AM
DOAUSI
  • 16 POSTS
Roy! Sent a message about the inspection and findings.
Dec 5, 2018 at 5:53 AM
Sorry, did not show up here on the post.
Dec 5, 2018 at 6:24 AM
DOAUSI
  • 16 POSTS
Okay! There is no visible leak around the master cylinder, booster, or proportion valve. While my friend was pushing the pedal I could hear the piston moving in the master cylinder. I also noted that the fluid would jump when the pedal was pushed. Is this normal?
Dec 5, 2018 at 6:36 AM
Yes, the piston seals may be bad internally.
Dec 5, 2018 at 7:02 AM
DOAUSI
  • 16 POSTS
Not quite sure of your reply. Are you thinking the seals inside the master cylinder may be worn? I have seen the repair kit on line is this worth the price? I only looking at this from the point that I bought the truck in 1994 and nothing has been changed in the way of booster, master cylinder, or proportion valve. I will still go ahead and re-bleed the brakes just to be sure.
Thanks,
Dec 5, 2018 at 8:32 AM
Yes, the ones inside.
I would be leery about rebuilding. If the bore is pitted, it is no good. In the old days with cast iron masters, we could hone them and then use new seals. With today's aluminum cylinders, you cannot even clean them up.
I would replace the cylinder only.
Dec 5, 2018 at 7:32 PM
DOAUSI
  • 16 POSTS
Thank you Roy, I feel sure that the master would need replacing as it has been decades since the truck was bought. And nothing lasts forever.
Thanks,
Dec 5, 2018 at 11:51 PM
You are welcome.
Always glad to help.
Dec 6, 2018 at 12:00 AM
