1984 GMC S15
1984 GMC S15
245,000 MILES • 4 CYL • 2WD • AUTOMATIC
GORDONJA
I'd like to switch from rear drum brakes to disc brakes. Is it possible& what would i need?
Jun 26, 2010 at 2:26 AM
HMAC300
  • 48,601 POSTS
there are probably alot of kitsout there to change over from drum to disc on S trucks, check some of the truck magazines i'm sure they will have them listed. If you try to do it yourself, you'll have to change the master cylinder as well as proportioning valve and mounts. for the disc set up.
Jun 27, 2010 at 1:19 PM
