Brake pedal goes to floor after replacing brake caliper on the rear.
100,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MARKRIOJAS968
  • 7 POSTS
brake pedal goes to floor after replacing brake caliper on the rear. what is sequence for bleeding brakes?
Jan 20, 2018 at 10:02 AM
SQM
  • 6,383 POSTS
Anytime a caliper, hose or master cylinder gets changed, the brake needs to be bled to get the trapped air out.
Here is a helpful guide on how to properly bleed the brakes:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
I have attached the brake bleeding sequence for your Lincoln below.
Oct 9, 2021 at 1:12 PM
