coming to a complete stop my truck jerks back and forth
126,000 MILES • 4.2L • 2WD • AUTOMATIC
JEROME SMITH
Okay, when I am coming to a complete stop my truck jerks back and forth plus my brakes go all the way to the floor. I have replaced my wheel hub bearing. I have replaced the brake caliper and also the front brakes. I am pretty sure it is coming from the front end of the truck. the only thing I need done so far is a front end alignment. not sure If that the cause of the jerking. so what could be causing it to jerk when braking and why is my brakes going all the way to the floor when stopping new brake pads?
Mar 15, 2018 at 2:33 AM
  • 110,246 POSTS
Replacing front brake pads and rotors really isn't too hard. You can expect to get around 25,000 miles from a set of pads, but that is based on driving habits and terrain. Changing them yourself can save you a lot. If you get lifetime parts from a parts store and do it yourself, you shouldn't have to pay for brake pad replacement again.
First, here is a link that shows in general how the process is done:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
_______________________________
2007 Chevy Truck TrailBlazer 2WD L6-4.2L
Front Disc Brake Pads Replacement
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Removal and Replacement Front Disc Brake Pads Replacement
FRONT DISC BRAKE PADS REPLACEMENT
Caution: Refer to Brake Dust Caution.
Removal Procedure
pic 1
1. Inspect the brake fluid level in the brake master cylinder reservoir.
2. If the brake fluid is midway between the maximum-full point and the minimum allowable level, no brake fluid needs to be removed from the reservoir before proceeding.
pic 2
3. If the brake fluid level is higher than midway between the maximum-full point and the minimum allowable level, remove the brake fluid with appropriate tool to the midway point before proceeding.
4. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
5. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
pic 3
6. Compress the front brake caliper pistons.
1. Install a large C-clamp over the top of the brake caliper housing and against the back of the outboard brake pad.
2. Slowly tighten the C-clamp until the pistons push into the brake caliper enough to slide the brake caliper off the rotor.
3. Remove the C-clamp from the brake caliper.
pic 4
7. Remove the lower mounting bolt from the guide pin.
pic 5
8. Rotate the brake caliper upward until it stops.
pic 6
9. Remove the outboard brake pad.
pic 7
10. Remove the inboard brake pad.
pic 8
11. Remove the brake pad retaining clips from the brake caliper mounting bracket and discard.
12. Remove all foreign material from the brake caliper using denatured alcohol.
Installation Procedure
pic 9
Important: When installing new brake pads, DO NOT reuse the old retaining clips for the brake pad. Use only NEW brake pad retaining clips.
1. Install the brake pad retaining clips to the brake caliper mounting bracket.
pic 10
Important: Use care when installing the pad so the spreader springs are not excessively deformed.
2. Install the inboard brake pad.
pic 11
3. Install the outboard brake pad.
4. Rotate the brake caliper down into position.
pic 12
Notice: Refer to Fastener Notice.
5. Install the lower brake caliper guide pin bolt.
Tighten the brake caliper guide pin bolt to 64 N.m (47 lb ft).
6. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
7. Lower the vehicle. Refer to Lifting and Jacking the Vehicle.
8. Fill the brake master cylinder reservoir. Refer to Master Cylinder Reservoir Filling.
Caution: Refer to Firm Brake Pedal Caution.
9. Pump the brake pedal slowly and firmly to seat the brake pads.
10. Burnish the new brake pads. Refer to Brake Pad and Rotor Burnishing.
_________________________________________
Rotor Replacement
Front Brake Rotor Replacement
Vehicle Brakes and Traction Control Disc Brake System Brake Rotor/Disc Service and Repair Removal and Replacement Front Brake Rotor Replacement
FRONT BRAKE ROTOR REPLACEMENT
Tools Required
J 42450-A Wheel Hub Cleaning Kit
Removal Procedure
pic 13
pic 14
3. If the brake fluid level is higher than midway between thew maximum-full point and the minimum allowable level, using a appropriate tool, remove the brake fluid to the midway point before proceeding.
pic 15
6. Compress the front brake caliper piston.
2. Slowly tighten the C-clamp until the piston pushes into the brake caliper enough to slide the brake caliper off the rotor.
pic 16
7. Remove the mounting bolts from the brake caliper mounting bracket.
pic 17
Important: When performing the following service procedure, the front brake caliper assembly and the front brake caliper mounting bracket can be removed as an assembly.
8. Remove the brake caliper and mounting bracket assembly. Refer to Front Brake Caliper Bracket Replacement.
pic 18
9. Remove the retaining clips from the brake rotor.
pic 19
Notice: Whenever the brake rotor has been separated from the wheel bearing flange, clean any rust or foreign material from the mating surface of the rotor and flange with the J 42450 hub cleaning kit. Failure to do this may result in increased lateral runout of the rotor and brake pulsation.
Important: If the brake rotor is not going to be replaced but just removed from the front hub, mark the relationship of the brake rotor and a wheel stud.
10. Remove the front brake rotor from the wheel hub.
pic 20
11. Using the J 42450-A, clean the brake rotor contact area on the front hub.
pic 21
Important: Ensure that the relationship marks on the brake rotor and the wheel stud are aligned before installing the brake rotor.
1. Install the brake rotor to the wheel hub.
pic 22
2. Install the brake caliper assembly to the steering knuckle.
pic 23
3. Install the brake caliper mounting bolt.
Tighten the brake caliper bracket mounting bolt to 150 N.m (110 lb ft).
4. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
5. Lower the vehicle. Refer to Lifting and Jacking the Vehicle.
6. Fill the brake master cylinder to the proper level. Refer to Master Cylinder Reservoir Filling.
7. Pump the brake pedal slowly and firmly in order to seat the brake pads.
8. Burnish the replaced or refinished rotors. Refer to Brake Pad and Rotor Burnishing.
__________________________________________________
I hope this helps. Let me know if you have other questions
Take care and God Bless,
Mar 30, 2021 at 2:29 AM
