Brakes were replaced and now pedal goes to the floor.
260,000 MILES • 0.6L • 4 CYL • FWD
MELANIE SAVAGE
Jan 29, 2017 at 12:17 AM
SQM
  • 6,383 POSTS
There are few reasons of why the brake pedal goes to the floor.
It could be due to air in the brake lines, low on fluid, leak in the brake system or a bad master cylinder.
Here is a helpful guide that address the common causes:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Air in the brake line is one of the most common causes. Especially after a brake service. Let's say if the caliper or the hose were replaced, this will allow air into the brake lines. Then if the brake system does not get bled properly it will have air trapped and cause the pedal to go to the floor.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
If the pedal still goes to the floor after the bleeding, then the issue is likely a bad master cylinder and will need replacement.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
I have attached the proper brake bleeding procedure below.
Oct 22, 2021 at 4:54 AM
