Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Brakes
Pads
Rear
pads and rotor installation
2008 TOYOTA AVALON
167,000 MILES
CARLA ROBERSON
MEMBER
1 POST
brake pads and rotor installation please help.
Aug 24, 2016 at 10:07 AM
Experienced Mechanic
Here is a guide that will help with this: Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Here is a guide on how to retract rear calipers: This video shows the job being done on a similar car but the process is the same.
https://www.youtube.com/watch?v=j8YwfSKEzZo&t=29s
Below is the process from the manual that will show how to do this. Please let us know if you have other questions. Thanks
Images (Click to enlarge)
May 10, 2021 at 10:48 AM
ASHSUZAN
MEMBER
can I change the rear brakes?
May 17, 2021 at 10:10 AM (Merged)
Here are some guides that will help with this:
Plus below you will find the info from the manual on how to replace the rear brakes.
Please run through this material and let us know if you have other questions. Thanks
Add image or video
Ask a new question
Engine won't start
Check engine light
