Brakes dragging
2004 SATURN VUE
84,320 MILES • 4 CYL • 2WD • MANUAL
HUMBOLDTHONESTY
First began when I drove an hour inland where climate was hotter while driving it felt like the brakes where slightly on. When I got back to the coast driving return back to normal. But now it always feels like the brakes are slightly on varying in resistance. If I put it in neutral while driving the car does not coast as far as it should.
I took the front driver side wheel off put the car in neutral with e-brake off and it was hard to move the hub.
Besides the brakes on three other occasions I could not get the car over forty mph, the car would just bog out when shifting into fourth gear.
Appreciate any insight on how to fix these problem's. Thank you for your time.
Nov 7, 2016 at 1:33 AM
JIS001
  • 3,412 POSTS
Pull the master cylinder out and look inside the booster for brake fluid. Very common problem for master cylinder to leak and booster sucking in oil. If that is the problem then you will need to replace the brake master and booster.
Nov 7, 2016 at 1:55 AM
JOHNNY G.JR
  • 320 POSTS
Could be a brake caliper hanging up, clogged brake hose also. Are all four wheels hard to turn?
Nov 8, 2016 at 12:58 PM
SATURNTECH9
  • 30,869 POSTS
So which wheels are sticking all four or just some?Which ones?
Nov 10, 2016 at 10:49 PM
