Brakes replacement
106,000 MILES • 6 CYL • 4WD • AUTOMATIC
VINCENT98
What brakes do i need for the car listed above?
Nov 4, 2019 at 9:34 AM
I attached pictures of the front brake pads and rear shoes. Here is a link to a common parts website that should help get you what you need:
https://www.rockauto.com/en/catalog/saturn,2005,vue,2.2l+l4,1431270,brake+&+wheel+hub,brake+shoe,1688
Also, I attached the OEM part numbers. The last two show the brake pad part number and then the shoe part number.
Let me know if you need the procedure on how to replace these as well. Thanks
Mar 8, 2021 at 1:27 AM
