Brakes
100,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SIERRA GUY
  • 21 POSTS
Brake pedal slowly sinks to floor. Also noticed rear drum brakes sometimes grab when backing up.Could the proportioning valve be the root of my problem? Cannot find any leaks and fluid is full. If I change the master cylinder should I also change valve?
Jul 4, 2016 at 3:54 AM
CJ MEDEVAC
  • 11,000 POSTS
I'd rule out the P-valve till last, they seldom mess up.
I'm going with the possible "internal leak" (fluid leaking past the plunger/ o-rings in the bore) in the master cylinder
Bench bleeding is a challenge on the bench- I do it on the vehicle (takes 2 folks but works fast!)
This 1st video may show the process that needs to happen/ couple it with the 2nd video (a little cruder video) You'll see how much EZier I think it is.
https://www.youtube.com/watch?v=9bEPrO99B5A
Here's the actual "on vehicle" process
https://www.youtube.com/watch?v=i3Jhbz4mVKw&feature=related
These are videos I found-They ain't mine at all!
Down here is another answer I gave, it may aid you too
https://www.2carpros.com/questions/1980-jeep-cj7-cj-brake-problem
Return with good news!
The Medic
Jul 4, 2016 at 4:31 AM
SIERRA GUY
  • 21 POSTS
Success, everything is copacetic.
Murphy only reared his ugly head twice.
Thanks for your help, Tom
Jul 10, 2016 at 5:21 AM
CJ MEDEVAC
  • 11,000 POSTS
Just for giggles
Did any of that help? Or did you go another route?
If so, what was most beneficial?
The Medic
Jul 10, 2016 at 7:04 AM
SIERRA GUY
  • 21 POSTS
Bleeding the master on the truck was a big help since there were two of us. Only took maybe 25-30 strokes. The idiots at autozone were almost no help at all. The bleeder kit consisted of two plugs. Once master was bled did have to bleed all 4 wheels 5 times to get all the air out. Did it in order every time.
Thanks again
Jul 10, 2016 at 9:46 AM
CJ MEDEVAC
  • 11,000 POSTS
So now,
Looks like you owe me lunch!
8 Krystal Burgers and a Coke would probably do it!
LOL!
Glad you got it and I was able to help somewhat,
Send your pals here too, we've got many fellers that know their stuff answering questions!
The Medic
Jul 10, 2016 at 11:05 AM
