Brakes
94,000 MILES • 1.4L • TURBO • MANUAL
NATASHA GOULDING
Had to brake heavily after that the brakes were not working properly, and when I got to my destination fluid was coming out of rear driver side wheel.
Jul 16, 2016 at 8:24 AM
CARADIODOC
  • 34,414 POSTS
Either a wheel cylinder is leaking, a steel line is rusted through, or a rubber flex hose popped a leak. Of those, none are terribly serious or expensive to repair.
Jul 16, 2016 at 10:26 AM
NATASHA GOULDING
Thank you. would this cause my brakes not to work properly?
Jul 16, 2016 at 6:05 PM
CARADIODOC
  • 34,414 POSTS
"Not work properly" can mean a dozen different things, but, yes, absolutely a leak will cause problems.
Jul 17, 2016 at 1:39 PM
