Brake warning light
150,000 MILES • 6.4L • V8 • TURBO • 2WD • AUTOMATIC
PERLA1428
Brake warning light come on I park the truck next day. Mechanic say power booster and master cylinder are bad. I replaced both when the truck is off brake are good when I turn engine on pedal goes down to the floor. I cannot get the truck on gear with not pressure in brake pedal. Please help. My truck is a super duty diesel power-stroke 6.4L. Thank you
Nov 2, 2018 at 3:52 PM
  • 55,694 POSTS
You must have the ABS valves opened using a scanner to get the air out. Here is a guide to help us see what is going on. Also, did he use a new master and bleed it on the bench?
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Cheers, Ken
Nov 4, 2018 at 3:35 AM
