Yea, two bled & two wont also replaced far rear hose, it calapsed i think
Jan 10, 2016 at 10:52 AM
69L88
MEMBER
It will act as if its bled and after start goes to floor
Jan 10, 2016 at 10:55 AM
PACO8224
✓Experienced Mechanic
Does it go to floor slowly after start? Or just fast with no pedal at all
Jan 10, 2016 at 11:06 AM
69L88
MEMBER
Very slow with some effort also
Jan 10, 2016 at 12:20 PM
PACO8224
Check to verify there is no lines leaking nowhere. After checking that and you do not see no brake fluid leaking nowhere replace the master cylinder, there is a internal leak in the master cylinder if no visual leaks are found.
Jan 10, 2016 at 12:24 PM
69L88
MEMBER
Thank you,i never had experience ,and didn't knoe symtoms.
Jan 10, 2016 at 12:30 PM
PACO8224
Any time. Come back and check with us, we are happily to assist you.
