When stopping the brakes push back against my foot and makes a noise?
138,000 MILES • 6 CYL • 4WD
TRESAPOTTER
Sep 9, 2023 at 2:24 AM
  • 110,251 POSTS
It sounds like the ABS system is actuating. Do you find it takes a longer distance to stop or do you have to press harder on the brake pedal?
I suspect it is likely related to a failing wheel speed sensor. That is where I would recommend starting to check.
If you have a live data scan tool, go to wheel speeds and while driving, see if each wheel is turning at the same speed. If one of the sensors is off, that can cause this to happen.
Also, if you don't have a scan tool, you can check to see if there is a sensor that is bad using a voltmeter or multimeter.
Here is a link that shows how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know if that is something you are comfortable performing. Also, let me know if the ABS light or traction control light is on.
joe
Sep 9, 2023 at 1:54 PM
TRESAPOTTER
Yes, my light is on thank you for the answer I'll check it out tomorrow and let you know. also, now I've got like a thumping in my steering wheel and gas pedal I can feel when I get to about 55. any thoughts?
Sep 14, 2023 at 11:35 AM
  • 110,251 POSTS
It could be a few things causing that. It could even be related to the brakes hanging up. Most commonly, it is a bent rim or balance issue with the tires. Is there anything you can do that changes what you feel? For example, if you apply the brakes does it go away or get worse?
Sep 14, 2023 at 11:49 AM
TRESAPOTTER
It goes away.
Sep 14, 2023 at 11:55 AM
  • 110,251 POSTS
If it goes away, check to make sure there are no issues with the steering components. Check for a loose tie rod or ball joint.,
I attached a pic below and highlighted the things to check for play. The wheel will need to be off the ground.
Let me know what you find.
See pic below.
Sep 14, 2023 at 12:10 PM
