Hi Katty,
Does the noise happen all the time or just when you apply the brakes?
If the noise happens all the time and gets louder when you increase in speeds, I would suspect a hub bearing/axle bearing before brakes.
However, if the noise is only there when you hit the brakes, then you may be correct with it is coming from the brakes.
Here are a couple of resources that will help narrow this down:
https://www.2carpros.com/articles/vehicle-grinding-noise
https://www.2carpros.com/articles/car-howling-noise
Thanks. Let me know if you need more assistance.
Kenny
Apr 13, 2019 at 1:12 AM
