sounded as if ABS was engaging
15,000 MILES
MUSTANGGUY1
my dad was going to do a brake stand the other day, and he dumped the clutch and went for the brakes, but it sounded as if ABS was engaging before I hit the brakes at slow speeds?
Apr 30, 2013 at 11:13 AM
Are you sure the ABS was engaging or was the clutch slipping really bad to cause a vibration and shaking that feels like an ABS?
Clearly if you are dumping the clutch and the brakes are not yet applied then it is unlikely to be an ABS event.
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
If this does not happen when hitting the brakes in normal conditions then again, I doubt the ABS is activating.
Does the clutch grind in any gears or hard to engage? If so, this is a clutch issue.
https://www.2carpros.com/articles/how-to-replace-a-clutch
Please review this material and let me know if you have questions. Thanks
Mar 5, 2021 at 10:14 AM
