Front brake pad replacement
131,456 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
CORY2427
  • 293 POSTS
Which is better for everyday use and get the most braking ceramic, organic, semi metallic?
Feb 9, 2019 at 12:13 PM
  • 55,733 POSTS
If I can jump in here. I like the semi metallic because they have a less tendency to squeak but the ceramics do last if you can keep them quiet. Here is a guide to help walk you through the steps of replacing the pads with diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Feb 10, 2019 at 2:49 AM
CORY2427
  • 293 POSTS
Thank you!
Feb 10, 2019 at 11:29 AM
PORKI
Hello to All, I have a problem i need to replace the front brake pads and rotor but don't know how?
Feb 7, 2021 at 1:28 AM (Merged)
  • 110,248 POSTS
The Yaris wasn't offered in the US in 2005. However, here is a link that shows how brake pads and rotors are replaced on a front wheel drive vehicle. I'm confident it will get you through the procedure.
If you run into any trouble, let me know.
Take care and God Bless,
