Service stability light comes on and the ABS light comes on?
85,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
KANUI MOIHA
Service stability light comes on and the ABS light comes on.While bleeding the brakes the rear driver side brakes do not work and had no fluid while bleeding. I changed the outer brake hose to caliper and nothing. Trying to avoid going to dealership to fix. Any help is much appreciated. Mahalo
Apr 23, 2016 at 12:04 PM
More then likely this is a speed sensor but we need to start with what codes you have.
Here is a guide that will help pull the codes:
https://youtu.be/Pb6nXV-iamI
Once we know what the code is we will have a better idea what to do but I suspect have a sensor issue so here are some guides for this as well:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below you will find the process from the manual on how to replace this as well.
Please let us know what questions you have. Thanks
Mar 8, 2021 at 10:07 AM
