Brake light stays on
210,000 MILES • 6 CYL • TURBO • 4WD • MANUAL
FRANK ZEIGLER
Brake light stay on, continuously, when ignition is on.
Jun 27, 2020 at 3:21 AM
  • 110,248 POSTS
At the top of the brake pedal is the brake light switch. I attached a picture to help locate it. Unplug it and see if the light goes off. If it does, replace the switch. If it stays on, then we have a short to power after the switch.
Let me know what you find.
Jun 27, 2020 at 1:07 PM
FRANK ZEIGLER
Installed new brake light switch. Left brake light still stayed on, dim and blinking. The right side brake light was always working okay. So I wired both brake light to the right side brake light wiring. They work fine.is there a problem with wiring them that way?
Jun 29, 2020 at 12:06 PM
  • 110,248 POSTS
The only concern is if the power being drawn is too much for the wiring. You have basically doubled the load of the wiring to the one side. I attached a pic of the wiring. Note there is a left and right send from the integrated power module, IPM. If I had to guess, the pin in the module has corroded or is partially broken and is shorting to power.
Honestly, it isn't something I would suggest. Just keep an eye on things. For the first few days, make sure nothing on the wiring seems to be overheating.
Jun 29, 2020 at 1:49 PM
