Brake warning light
110,000 MILES • V6 • 4WD • AUTOMATIC
SBORZILLERI
The other morning my brake warning light came on for a few seconds then went off. It has continued to do this for the next few days. The light will go on a few seconds then turn off for awhile. The brake fluid is full a and the brakes are working fine. I'm not sure why if there was a problem the light wont stay on solid.
May 13, 2020 at 5:57 AM
Good afternoon,
Do you mean the yellow ABS light that is on? That would be an indication of a fault in the ABS system. I would need the code to help narrow the area of failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
If it is the red light, either the float level switch or the switch for the parking brake is the issue.
May 13, 2020 at 6:41 AM
SBORZILLERI
It is the red light. Thank you, I'll check on the two switches you mentioned. This was very helpful. Thanks again!
May 13, 2020 at 8:01 AM
You are welcome.
Always glad to help.
May 13, 2020 at 8:06 AM
