Brake Travel, I feel a bit of a dip shortly before the stop?
121,690 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DMHUGGINS26
  • 24 POSTS
When I approach a stop holding down the brake pedal lightly (at less than 45%), I feel a bit of a dip shortly before the stop. I have had the pedal go really soft twice before (after it hit "the dip"). I'm thinking I have an internal leak in the master cylinder. No codes are showing. Thoughts? Thanks.
Feb 17, 2024 at 5:49 AM
  • 110,248 POSTS
Chances are, the master cylinder isn't a problem, but anything is possible. If you feel a slight dip or drop in the brake pedal, it could be related to the ABS. However, that would have likely set an engine light.
Since you mentioned the master cylinder, try this. With the engine running and the vehicle parked, press on the brake pedal and hold pressure on it. See if it slowly starts lowering to the floor. If it does, then the Master Cylinder is likely failing, and the fluid is bypassing the plunger. If there is no drop, the Master Cylinder is likely fine.
Try this and let me know what you find.
joe
Feb 17, 2024 at 11:09 AM
DMHUGGINS26
  • 24 POSTS
I will try that. Are there any other thoughts on what it could be?
Feb 18, 2024 at 8:09 AM
  • 110,248 POSTS
I have felt similar things when the ABS would actuate. Also, it could be related to brake hardware. Are the brake pads/shoes in good condition? Have you checked to make sure none of the slid pins on the caliper need to be cleaned and lubricated?
Feb 18, 2024 at 10:53 AM
DMHUGGINS26
  • 24 POSTS
The brake pads are quite old. I haven't heard them generate any noise, so I haven't really faulted them. The fluid was also over 2 years old both times they did this. I read that fluid should be changed every 2 years, so I did do that recently. If this was an ABS issue, wouldn't the ABS light come on? Thanks.
Feb 20, 2024 at 12:44 AM
  • 110,248 POSTS
If the ABS module is signaling a traction issue falsely, no, it wouldn't know there is a problem; it only knows the information provided.
You may want to check the brakes themselves to make sure the brake hardware or slide pins are still good. A slid pin or rusty/corroded hardware can cause something like this to happen if a pad is sticking.
Feb 20, 2024 at 11:28 AM
DMHUGGINS26
  • 24 POSTS
One more bit of information I forgot to put in: The excessive brake travel stops after I restart the car.
Feb 21, 2024 at 10:18 AM
  • 110,248 POSTS
That is an interesting addition. Brakes can be pumped to regain a solid pedal. Could be that what you are experiencing?
Feb 21, 2024 at 11:01 AM
DMHUGGINS26
  • 24 POSTS
Well, that's just the thing. I have pumped them like crazy when the car showed the issue and was stationary but still on, and the pressure never came back. After I restarted the car, pressure returned.
Feb 22, 2024 at 3:19 AM
  • 110,248 POSTS
There is a brake booster pressure sensor mounted on the vacuum brake booster under the hood. (see pic below).
Do me a favor. Check the electrical connector on that sensor. Remove it and inspect the connector pins to make sure there is no damage or corrosion that may be causing an issue.
See pic below.
Feb 22, 2024 at 12:14 PM
DMHUGGINS26
  • 24 POSTS
Sorry for late reply. I will definitely look into this. I looked up a video of a guy on YouTube who changed out this part and he said he was experiencing the same vehicular symptoms as me. Wouldn't a bad brake booster sensor cause a stiffer brake pedal though?
Feb 25, 2024 at 3:00 AM
  • 110,248 POSTS
The sensor can cause a stiff pedal or one that is too soft.
Let me know if I can help in any way.
Take care of yourself.
Feb 25, 2024 at 10:41 AM
DMHUGGINS26
  • 24 POSTS
Okay, so I think I found what could be this issue. I took the sensor out, but it looked fine. I will have pictures below. No corrosion that I could see on/in any of the sensor or the wires. However when I removed it, it seemed to leak booster pressure a bit too easy. Just by rotating the sensor to loosen it, I could hear pressure releasing. When I put it back in, the bottom right of the hole was loose. I took a picture of the hole and I can't tell if it is a washer seal issue or an issue with the threads in the hole of the booster. I will attach a picture of the hole and you can zoom in on that bottom right to see what I mean.
Feb 26, 2024 at 12:49 AM
DMHUGGINS26
  • 24 POSTS
Here is a larger image of the hole.
Feb 26, 2024 at 12:55 AM
  • 110,248 POSTS
Where the sensor mounts doesn't look out of the ordinary. Also, when you turn the sensor, it releases pressure, and you will hear the vacuum. It could be the sensor itself.
Let me know
Feb 26, 2024 at 11:09 AM
DMHUGGINS26
  • 24 POSTS
Okay. Well, I suppose I am going to replace that sensor. I saw they typically come with a new rubber grommet too. How sure do you think the sensor is the issue? Just double checking because it looks a bit pricey. Lol Because the problem has been so intermittent, it also will take me a while to tell if that fixed the issue.
Feb 27, 2024 at 2:37 AM
  • 110,248 POSTS
Based on the symptoms, I would think it's a 50 - 50 chance. You may want to scan the can-bus to see if there are any codes stored in the ABS module.
CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link showing how it's done:
Feb 27, 2024 at 10:12 AM
DMHUGGINS26
  • 24 POSTS
Okay. Thank you so much. I really appreciate all the help you have given. Sorry for so many questions. I think I am going to order the part regardless to get a new grommet as well. The sensor was so loose in the grommet that was installed. I think I am going to look into getting a scan tool because of the engine surge issue I have going on as well.
Feb 28, 2024 at 1:31 AM
  • 110,248 POSTS
You are very welcome. I hope this takes care of the issue. Also, if there is a leak from the sensor (you mentioned it wasn't tight in the grommet) that could be causing air/fuel mixture issues and the engine surge.
As far as scan tools are concerned, in this day and age, I feel everyone should have one. When you decide to get one, try to find one that will scan the "CAN-bus" system. You can get basic ones for excellent prices. CAN stands for controller area network. A basic scanner will likely only read engine codes. If you get one that scans the CAN, you can retrieve codes from different modules, including the ABS module.
Let me know how things turn out for you or if there is anything I can do to help.
Feb 28, 2024 at 10:36 AM
DMHUGGINS26
  • 24 POSTS
Sorry to bother again. but I need help finding the part. I used a GM parts website, but it almost looked as though this sensor was not listed. Many impalas of the late 2000s I believe have a "vacuum check valve" instead of this sensor. I could be wrong on some of this, but this was what I have inferred or concluded from my research. I then looked up what I thought was the part number, (18085957) but I'm guessing that is just what GM put on to identify what item on the stock impala that was. I can only find like 3 or 4 sensors with that number online and they are all used. The other number I looked up on the part, (the 261230121) I am guessing is the part number used by Bosch to identify the unit. I have found many online with that number that were often made after my car's model year. Is this 261 number the number to go by? Would it be more beneficial to just install the vacuum check valve instead? Thanks.
Feb 29, 2024 at 3:03 AM
  • 110,248 POSTS
Wow, I see what you mean. I checked as well, and everything indicates out of stock or discontinued. The manufacturer is required to manufacture the part for 10 years after production. So, that means GM is no longer responsible. However, that doesn't help.
Try this. Contact the local Chevrolet dealership and ask if they can locate any dealer old stock (DOS) sensors.
Feb 29, 2024 at 12:32 PM
DMHUGGINS26
  • 24 POSTS
Okay, so I just sent messages to like 7 dealerships around me. What happens in a situation like this if you can't find a replacement part? I would think this is common for even older models.
Mar 1, 2024 at 2:53 AM
  • 110,248 POSTS
If you are unable to find a new factory part or aftermarket part, the next thing to do is check a salvage yard or somewhere like Ebay for a known good used one.
I wish I had a better answer, but this is the reality of this type of problem. Also, just out of curiosity, contact a local parts store and ask if they have a power brake booster for your vehicle. If they do, see if it comes with the sensor.
Mar 1, 2024 at 11:43 AM
