Brake system switchover
20,000 MILES • 4.3L • V8 • 2WD • MANUAL
SHAWNEETUCKER
Will calipers and rotors off of a 1995 Mustang GT fit on a 1965 Fastback Mustang?
Nov 23, 2017 at 8:49 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
As far as the front rotors go I am seeing that as a no. I compared the two Bendix rotors at summit racing, one being 276 mm in diameter and the other is 287 mm.
https://www.summitracing.com/parts/ben-prt1911/overview/ and https://www.summitracing.com/parts/ben-prt1017/overview/year/1965/make/ford/model/mustang
The calipers on the 1965 appear to be dual piston but on the 1995 are single piston, so again, that would be a no.
Nov 24, 2017 at 12:04 AM
SHAWNEETUCKER
Will front end of the 1995 bolt up to the 1965?
Nov 24, 2017 at 1:11 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
SHAWNEETUCKER
Thank you I appreciate your knowledge. One more question would front end of 1994 fit if I used its frame lime a sub frame?
Nov 24, 2017 at 3:08 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I would have to say yes, because it would basically be a 1994 with a 1965 body.
Nov 24, 2017 at 3:38 AM
SHAWNEETUCKER
Thank you appreciate your help. You answered in a timely manner nice to have someone to ask you can count on. Happy holidays
Nov 24, 2017 at 1:17 PM
  • 55,764 POSTS
PATENTED_REPAIR_PRO is one of our best!
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Nov 27, 2017 at 7:41 AM
