ABS light turned on after replacing bearing assembly, ball joint, and sway link bar
2004 FORD TAURUS
113,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GENE SPEARS
i just recently had to replace the wheel bearing; assembly, ball joint, and the sway link bar. now the ABS light is on. what might be the problem?
Oct 13, 2019 at 1:55 AM
AL514
  • 5,668 POSTS
Hello thanks for using 2CarPros. My guess is one of the wheel sensors for the ABS was either left unplugged. If you take a look at all 4 of them at each wheel you'll probably find the issue. One other issue I have seen is a wheel bearing installed that didn't have an ABS sensor. Each bearing should have wires coming out of it for the ABS sensor.
Oct 13, 2019 at 5:11 AM
