Brake squeals after the car warms up
100,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
RANDYDUNN10
  • 29 POSTS
Brake squeals after the car warms up. Does not do it when cold I think I need brakes
Oct 22, 2018 at 1:36 AM
RANDYDUNN10
  • 29 POSTS
See what you think.
Oct 24, 2018 at 6:10 AM
  • 110,251 POSTS
Replacing rear brake shoes and the drums can be a challenge, but if you take your time and follow the directions, you should be fine. You can expect brake shoes to last approximately 30,000 miles, but that is based on driving habits and terrain.
First, here is a link that you may find helpful. It shows in general how it is done. You can use this as a guide.
https://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
Here are the directions specific to your vehicle. The attached pics below correlate with the directions.
Note: The directions include replacing the wheel cylinder. If it is not leaking brake fluid, this doesn't need done.
_____________________________________________
2009 Hyundai Accent L4-1.6L
Repair Procedures
Vehicle Brakes and Traction Control Drum Brake System Service and Repair Removal and Replacement Repair Procedures
REPAIR PROCEDURES
Removal
CAUTION:
- Frequent inhalation of brake pad dust, regardless of material composition, could be hazardous to your health.
- Avoid breathing dust particles.
- Never use an air hose or brush to clean brake assemblies.
1. Remove the shoe hold spring and shoe hold pin (B).
2. Remove the upper return spring (A).
pic 1
3. Lower the brake shoe assembly (A), and remove the lower return spring (B). Make sure not to damage the dust cover on the wheel cylinder.
pic 2
4. Disconnect the parking brake cable from the parking brake lever.
5. Remove the brake shoe assembly.
6. Disconnect brake tubes(A) from the wheel cylinder(B).
7. Remove the bolt (C) and the wheel cylinder(B) from the backing plate(D).
pic 3
Installation
NOTE:
- Do not spill brake fluid on the vehicle: it may damage the paint; if brake fluid does contact the paint. Wash it off immediately with water.
- To prevent spills, cover the hose joints with rags or shop towels.
- Use only a genuine wheel cylinder special bolt.
1. Apply sealant (C) between the wheel cylinder (A) and backing plate (B), and install the wheel cylinder.
pic 4
2. Connect the brake tubes (D) to the wheel cylinder.
3. Connect the parking brake cable to the parking brake lever.
4. Clean the threaded portions of adjuster sleeve (A) and push rod female (B). Coat the threads of the adjuster assembly with grease. To shorten the clevices, turn the adjuster bolt (C).
pic 5
5. Hook the shoe adjuster lever, then install it to the brake shoe.
6. Install the adjuster assembly and upper return spring (D) as right direction. Be careful not to damage the wheel cylinder dust covers.
7. Install the lower return spring (E).
8. Apply brake cylinder grease or equivalent rubber grease to the sliding surfaces shown. Don't get grease on the brake linings.
pic 6
9. Apply brake cylinder grease or equivalent rubber grease to the brake shoe ends and opposite edges of the shoes shown. Don't get grease on the brake linings.
pic 7
10. Install the brake shoes (A) onto the backing plate. Be careful not to damage the wheel cylinder dust covers.
11. Install the shoe hole down pins (B) and the shoe hole down springs.
pic 8
12. Install the brake drum.
13. If the wheel cylinder has been removed, bleed the brake system.
14. Depress the brake pedal several times to set the self-adjusting brake.
15. Adjust the parking brake.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 24, 2021 at 10:04 AM
VIC BOTE
how can we get the brakes changed out?
Feb 26, 2021 at 3:26 AM (Merged)
SEVAG P
  • 405 POSTS
hello,
Check out guide below how to replace rear brake pads and discs.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Check the diagrams below how to replace rear pads and discs .how to measure discs runout and thickness.
hope these helps.
thank you.
PIERCEDALPHAMALE
I cant seem to get my rear brake drum off. I dont want to break anything so untill i am certain what to do i havent been to forcefull. I removed the tire now what to get the drum off thanks
Feb 26, 2021 at 3:27 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Remove tire Spray penetrating oil on the drum center use a hammer and tap around the drum, which should free the drum and allow you to pull it out
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_705.jpg
RICHYHX1
hi, i think that my rear farside drum has gone. its making a squeek when i release the break pedal or jandbreak and has now started making a scraping noise when the wheel is turning. what do you think is wrong? how much is it likely to cost to get the work done?
Feb 26, 2021 at 3:28 AM (Merged)
  • 110,251 POSTS
It sounds like the brake shoes are worn out. The parts are cheap (maybe 25.00) and you can do it yourself. Here are directions:
https://www.2carpros.com/how_to/rear_brake_shoes.htm
